New Visual Building v 5.2.1.0 15 Jul 2015 10:41 #2243
This is a minor update with a few new features, but consists mainly of bug fixes:
Features:
1. File Open / Save dialogs extended to display file size and modification date
2. The diagnostic dialog extended to include more wall tests
3. If a room is already assigned to an apartment, an alert is activated with additional allocation.
4. When you have a wall selected, pressing the v key will activate the wall extend shorten wall tool.
5 When you have a wall selected, pressing the b key will activate the wall trim tool.
6 When you have a wall selected, pressing the c key will copy the wall and allow placement of the new wall using a reference point, via the activated Tools options dialog.
7 When you have a wall selected, pressing the r key will allow placement of the wall using a reference point, via the activated Tools options dialog.
8. Roof surfaces can now be merged if they are in different layers.
9. AutoText now also selectable for City and post code.
Fixed
1. Guidelines would not be properly removed when the view deleted.
2. Moving a chimney into another sheet or into another layer sets the chimney height correctly.
3. Moving a roof in another layer also now moves the associated timber structure or dormers.
4. Dormer walls are now properly created.
5. Circle segment on center and radius generates the correct segment.
6. Battens are shown after generation in all views. The visibility can be switchedon/ off / turned in each view.
Time to create page: 0.140 seconds
