unselectable wall 26 Sep 2016 19:44 #2607
  • James Mansion
  • James Mansion's Avatar Topic Author
Well, I tried. The wall was showing in the layer that is active. I had closed the 3D view after trying to select it there, so I re-opened 3D and the wall is gone! So I close the 2D view and reopen that, too - and its gone from there as well.
I suspect an MVC bug of some sort, the views seem out of sync with the model.
Still, I can progress again.
unselectable wall 26 Sep 2016 07:56 #2606
You can only select elements on the active layer which is marked red in our Project Viewer on the right side of the Software.
In your case you can move the mouse over the wall and check its layer in the appearing tool tip. Then activate the layer in the Project Viewer tree. Select it and set it as active element from the right mouse button context menu.
Alternatively you can keep the CTRL key pressed while you click on the wall in 3D. CTRL + left mouse click automatically activates the layer of the selected element.
unselectable wall 25 Sep 2016 17:43 #2605
  • James Mansion
I seem to have got an unselectable wall. It is greyed out in the 2D view, and visible but unselectable in 3D view.
This is with 5.2.1.0 that I downloaded yesterday (trial).
Any ideas how to get rid of it?
Time to create page: 0.155 seconds
