Changing guide lines snapping from the default 22 Oct 2014 09:48 #1768
  • Dean French
  • Dean French's Avatar Topic Author
Hi i have been doing this but it only worked twice maybe it switch it self off ill try again. ive watched the video a hundred times
Changing guide lines snapping from the default 22 Oct 2014 09:10 #1766
Then use CTL+W to change the between Inside edge, centre line and outside edge as the snapping point foe the wall.
Watch the following video at time 2:10 which explains this:
Changing guide lines snapping from the default 22 Oct 2014 08:58 #1764
  • Dean French
Sorry with a wall
Changing guide lines snapping from the default 22 Oct 2014 08:56 #1763
  • Dean French
I,m trying to snap to the inside making the guide line the outside dimensions of the building
Changing guide lines snapping from the default 22 Oct 2014 08:15 #1762
Are you trying to snap a guideline to another guideline or object, or are you trying to snap a wall to a guideline?
Here are some common items concerning snapping:
When snapping a wall use Ctrl+W to change the snapping point from wall edge to centre line.
Be sure that you have snapping switched on. Its easy to switch off in the Quick access toolbar (
nect to grid icon).
Snapping properties can be changed for different objects. Right click on Snap tool to activate the following propeties panel:
Changing guide lines snapping from the default 22 Oct 2014 07:34 #1761
  • Dean French
I have tried many times but only managed twice to change the snaping from the centre line to the inside of the line.
I just carnt see why
Time to create page: 0.200 seconds
