Here are the steps. Click on the buttons indicated in red:
1. Double click on the wall to activate this dialog: 2. Double click on the Layer construction button, which will activate this next dialog: 3. Double click on the Material button which will activate this dialog: 4. Double click on the 2D Display button |
Hi, all resolved on the original query, thank you, but I am still puzzled about your documentation section 19.6.6, changing fill patterns in wall layers. You seem to have a dialogue box open headed 'Building Materials', but I can't get there through the Wall layer construction dialogue box - using the Visual Building 5.2 version.
Thanks, Chris |
Thanks for the rapid reply - i have been up since 03.30 making good progress using the dropdown. There is another problem though, where the layer thickness can revert to the previous setting - possibly as layers are switched, but certainly seen when returning to that layer. One of those pesky intermittent problems..... ;-)
Anyway, good progress, and this is not confined to walls - it also happens on floors/ceilings. Chris |
