You may need to deselect some of the unwanted layers during the import process. Its also likely to be a matter of scale as
explained here
Hello.
I've been trying to import the attached DWG file into VB Premium. I can preview it in DoubleCAD and Autodesk Trueview but no matter what format I save or convert it to it won't import. I should be getting image A but get image B. I have imported other DWG files no problem. OS maps etc. Any ideas? Can you convert it to a manageable format? Thanks. |
