That fixed it :o)
for reference if anyone needs it the info is:- Retry starting Visual Building while disconnected from internet. If it does start while disconnected from internet exit program and then: 1. Delete all files in the following folder: C:\Users\YOURNAME\Documents\Visual Building Pro\Update 2. Start the program without being connected to the internet. 3. Create a new blank project 4. Select Settings menu, Program option 5. Then select Update page in the dialog. 6. On this Update page select manual search only. 7. Restart program, this time while connected to internet and see if problem re occurs. |
Please see this topic for solution
The problem can relate to the software in either trial evaluation or non trial evaluation mode. Also applies to all version on both x32 and x64 systems. The bug is in the actual update system, but once updated is rectified. |
