Well spotted. With the Environment layer switched on I can repeat your problem. I suggest you dont use the enivironment layer in this way and create a new layer for the large blocks you want, but although it works for what you want now you may limit your options later.
To resolve your problem select the environment layer and select each block on that layer and in the Selection tab select Send to back. The blocks will then appear behind your 2D walls instead of in front. |
