Re: Adding Hip Roof 17 May 2013 13:24 #764
  • 's Avatar
For creating additional roof sections onto an existing roof please take a look at the following:
Multiple gables
Please email us your project so we can advise you better specifically for your roof design.
Visual Building Basic does not have the Roof Merge and Advanced Roof Timber Edit features. These are part of Visual Building Premium v4
Adding Hip Roof 17 May 2013 13:20 #763
Hello I am adding a hip roof to a rectangular house. There are 2 supporting beams near the center of the house and the ridge of the roof should run between the 2 beams. When I add the roof there is no ridge. How do I create it between the 2 central beams? Also - is the roof independent of the various beams that I have defined? i.e. I assume there is no functionality that makes the roof sit on the beams. If there is no functionality to do this, then presumably I need to adjust the height of each beam so that it touches the roof?
SH via email
