Exhibition Shell Scheme Panels 20 Mar 2014 19:02 #1338
Is there such a thing as a standard panel? The companies that supply these panels seem to use very different dimensions and materials. In that demo we created 1m x 2.5m panels by resizing the cube object located in the catalogue.
Exhibition Shell Scheme Panels 20 Mar 2014 16:45 #1335
Seeing the visual you are using to promote you attending the show at NEC has put some questions in my head.
I assume you used Visual Building to produce the project- because i recognize the peolpe- I mean the models - not the actual persons.
In the catalogue there is a set of wall panels etc to help create an exhibition stand, but do you have any standard panels as used by show organisers for exhibition shell schemes. The panels in the catalogue appear more up market to those I am used to.
