If you are absolutely sure you selected English during the installation then please try reinstalling with any virus checker temporarily disabled. The virus checker may be preventing the language dlls from being installed.
During the installation process you have the option to select the default language, so be sure you have selected English. Which ever language you select, you should be able to change the language at any time using the Application menu (Green top left arrow), then select Settings (Einstellungen), then Language ( Sprache) and then the language. This assumes you selected the new ribbon interface at install time. You will then need to restart the application for the change to take effect. If you can not manually switch language then the problem is likely to be the incompleted installation as described above. If during the reinstall a dialog appears complaining a dll is in use, then select Ignore. |
I've just downloaded the trial version of .Basic' but despite selecting 'English' as the language all of the ribbon titles etc seem to be German. Is it possible to change the language from German to English.
Thanks |
