North Arrow - size and design 06 Jun 2014 08:54 #1526
You can disable the North Pointer in each view using the Visiblity dialog (Right click in the view) - de-selecting Help elements -North arrow. Each view has its own independent Visibility settings.
North Arrow - size and design 06 Jun 2014 08:31 #1525
  • Richard Robinson
  • Richard Robinson's Avatar Topic Author
Thank you.
When you say turn off the north point I guess you mean delete it? Then the imported north point is just a symbol without the function of the one turned off or deleted?
North Arrow - size and design 05 Jun 2014 16:10 #1524
You can find the standard north pointer as a 2D symbol in the Catalogue in the 2D Symbols/symbols folder.
1. Drag it into your project from the catalogue.
2. Double cklick on it and you will see the default size is 0.75m x 0.75
3. Change the size to what you want
4. Right click on symbol and select Save selected object as 2D Symbol
This will not replace the default North Pointer which you need to switch off and drag in your new pointer from the catalogue.
The default north pointer is in fact a 3D object that lives in:
C:Program Files (x86)\Visual Building Premium 4\Program \Data
You can also change the size of this object and save it in similar way using the Export as 3D Object (from the 3D View)
Applicable to all versions of Visual Building
North Arrow - size and design 05 Jun 2014 15:33 #1522
  • Richard Robinson
Thanks, how can the current one be resized to suit the 2d view being created. I am creating 2d survey view 1:100 and the symbol is too small.
North Arrow - size and design 05 Jun 2014 14:20 #1520
Yes the north arrow is just a 2D symbol generated from a 3D object and so you can easily create your own. It is a 3D object because it is also visible in the 3d view.
Copy to:
C:\Program Files (x86)\Visual Building Basic 4\Graphics2D\Symbole
Replace file called Nordpfeil_1.cys
North Arrow - size and design 05 Jun 2014 14:09 #1519
  • Richard Robinson
Is it possible to change size and design of the north arrow?
Thanks!
