The trees will take up a lot of your processing power, so its best to add such memory hungary features at end of project, after you have complete all other editing. Each tree possibly has as many polygons as your building. Im not sure what is with the cobble stones not displaying in 2D, but I would add them as a 2D texture on a strip instead of individual object elements, as again so many objects will use up memory. I have reported this as a bug, as its not possible to edit these, which should not be the case.
Hi. In my project I'm doing work on my driveway and I have created a line of cobbles/sets up both sides of drive using terrain elements/bed and then multiple copied to run full length of drive, It all works fine although it takes a long time to process multiple copies. The problem is when I save project then reopen at later date it is only then visible in 3d view. The only one visible are the first ones I created before doing the multiple copy, Am I missing something.
Carl |
