Hello! JPEG SIZE 18 May 2015 14:01 #2146
The jpg format is intended for web site presentation. If you need to use for printed brochure, which would need higher quality then export as pdf, and convert that to a jpg using any pdf to jpg conveter.
Hello! JPEG SIZE 14 May 2015 07:11 #2145
  • Jon Luddy
  • Jon Luddy's Avatar Topic Author
How do you increase JPEG size so estate agent client can transfer on to their brochures clearly?. They say the JPEG when received is too small, Before export I usually save the work, do a print preview.check for clarity it and then convert to JPEG and send. It does reduce size when converted to JPEG when I open to see it before sending and have to zoom to see it clearly. When received the other end they are now saying its too small and needs enlarging, They agents have recently updated their website. Is it me or them that is the problem? I havent had this prob before. Their software does not take PDF
