Here is a new lintel example also showing some block walling.
Normally you cant see the lintels in a 3D view but I assume you will show by applying a glass texture to the wall. In the Catalogue, click on Construction components - Profiles - Steel Profiles and here you will finf many different steel profiles which you can convert into steel beams. You can create your own Lintel profile and use Visual Building Premium's extrude tool to create a 3D object from the 2D profile. You then have the lintel as a 3D object. |
I have seen your example on how to create a concrete lintel above doors and windows, but in my project I need to show an IG steel lintel (100mm wall standard load with 75mm cavity). Any advice on how to draw and incorperate would be much appreciated. Im using Visual Building Premium which is a great product by the way.
AF via email |
