This appears to be related to the project being created wiith a 32 bit environment (v4) and now imported into a 64 bit environment (v5), and only affects specific graphic cards. It is easily rectified: just click on the New 3D View tool in the View - New Views tab. You will see the new created 3D view has all the textures displayed as expected, and you can now delete the previous 3D View.
I have just upgraded from Visual Building V4 to v5, and on loading my v4 project into v5 the project displays correctly except for when in Standard View or Presention, the textures do not display correctly as they did before.
If I activate the Raytrace feature, then the textures appear, so its not a case of the textures missing from the catalogue or project, but appears to be a display problem. Via email |
