Its generally accepted that most users have both a desktop and laptop and therefore we allow a single license to be installed on two machines owned by the user at the same time.
However each time you install Visual Building Professional or Premium it will give you a different serial number which you should submit in order to receive a license key for each machine. |
I have a question about the installation of Visual Building.
I do own a laptop as well as a desktop computer. Depending on or I work at home or elsewhere I use the desktop or the laptop computer.. My question is if I need to order a seperate license for each computer or can I use the license for Visual Building Premium used on the desktop computer also on the laptop computer? I did try to use the same license on the laptop, but it reply's that the license is not valid for that computer. Regards Joop Sluijmers |
