Ian,
Minor updates will be free, and the next minor update is now in test and will be available next month. We will include some new 2D objects with this and I think this includes some additional heating objects. |
Another thought. If you are upgrading for epc use it would be useful to be able to calculate the HLP and display the total length and breadth, and total area. This can be either inside or external dimensions. Thanks
Hi Thanks for the reply. I think that visual floorplanner is what I shall require. If I purchase now will I be able to update to receive the epc objects and do you know when this will be available? Thanks
Ian,
Visual Building and Visual FloorPlanner are two very different products. Please see this topic for for details on the comparison and objectives of both. In response to your specific questions: Saving same formats Both can save project as .pdf. jpg. png. Visual Buildings projects are .cyp specific to Visual Building, and Visual FloorPlanner saves its projects as an XML file. Can you have all floors on 1 plan Visual FloorPlanner: yes Visual Building: yes but with Professional version. EPC Objects In Visual Building you can easily create any 2D symbol you require. We are currently upgrading Visual FloorPlanner to include range of objects required for EPC. The current list of 2D objects found in Visual FloorPlanner is here . |
Hi I have been looking for a feature comparison between visual floor planner and visual building basic but cannot find one. I know that visual basic has the 3d facility but are there any other differences? For example can you save to the same formats in visual basic and is it as easy to use for 2d plans? Can you have the first and second floors on one plan? Much or my work is 2d and EPC's but the 3d facility may come in useful. Finally, do you have objects for boilers, radiators, water cylinders etc. for EPC floor plans? Thanks
