The language is changed using the Settings menu in the top menu bar. Use the Language entry to change the language. You will need to restart the program for this to take effect.
If in German you need to select the Einstellungen menu in the top menu bar. Use the Sprache entry to change the language. You will need to restart the program for this to take effect. |
