1. The Environment layer must be the current selected layer to be able to select the environment block
2. This will depend upon your screen resolution, but if you zoom in the grid dots will appear again. 3. The terrain objects only live on the Environment layer so ensure that this is your current layer. |
1:- Following instructions in tutorial part 1 no1, Changing the size of the environment. When I select environment as current element and then double click on tab the dialog box does not open.
2:-When altering the grid settings to below 100cm the dots/grid disappear, is this usual? 3:- My previous question about setting out the site plan. Using the Terrain elements,bed , insert with polygon. I dont seem to be able to create any visible shape. Am I doing something wrong? CD via email |
