The object you refer to is a .solid. You can drag this into your project, then right click on it and select Properties and change the objects original dimensions and details.
However its possibly easier to convert this to a .cyg object using Export / 3D Formats / 3D Object file ensuring you select Export selected Object only. Before you do this apply any textures / materials that you want on the object. Then select new object in your catalogue and drag into your project. Right click on it and select Properties, where you can change the height, BUT be sure to tick Scale distorted so that the other dimensions don't change. |
Can I shorten the length of the Balustrade Type 08 components , as if I try to do this the width automatically becomes smaller therefore it will not match the standard length component I’m trying to snap it onto.
JM via email |
