Yes, Any object that you create with the 3D construction tool in Visual Building Pro can be added to catalogue.
You can also create 3D objects in external 3D programs such as 3D Studio Max or Truespace (free) or Blender (free) and also import these into Visual Building Pro, and also include these in the catalogue. |
There are no lintels in the catalogue, however box lintels are easily represented by a 3D rectangular tube object in the catalogue. Other shapes, including box lintels are easy to create in Visual Building Pro using the extrude tool.
In this example I created the section shape and the extruded it in a 3D object.
Click on image to zoom
The above was achieved by adding a cut out in the wall to the full height of the wall and then dragging a RSJ (in this case an I beam) into the slot. I used the IBeam from the Objects - Components catalogue. This is possible in all versions of Visual Building. Download this project here With Visual Building Professional you can create additional beams of any cross section using 3D Construction tool. |
