The are two ways that you can use your 2 screens:
1. Drag the Visual Building application window so that it exists across both screens. You can then open 2D / 3D windows and view them on either screen. Most 2D / 3D views must exist within the application window (except some 3D views as follows) 2. Many dialogs have a 3D button allowing you to open a 3D view, for example when editing a roof, you can drag the roof editor outside of the application window. Applicable to all versions of Visual Building |
Everything's fine. Enjoying the prog. 1 simple question if I may.
I have tried to find in the prog Help and in the forum if I can send the 3D view to a second screen/seperate monitor. I have 2 monitors set up and functioning but cannot find if I can do this in the VB prog. RM via email |
