Please contact Visual Building directly by email so that we establish what other software you have and wish to upgrade to Visual Building from.
Hi, I also have an earlier version of this software but rom Focus (the software company not the shop) called Your 3D Home Designer, which is great value- but I need to be able to create my own 3D models (timber shapes from my car porch), and see that I can achieve this using the Visual Building Professional version. Can I upgrade from the Focus Your 3D Home Designer to Visual Building Professional? Your last answer mentioned a Competive Upgrade Discount but I cant find that stated anywhere on the web site or forum.
The Ashampoo 3D CAD Architecture products are based on the same CAD engine as Visual Building and your projects should load into Visual Building without problems. Altthough you will not be able to install your purchased objects and textures directly into Visual Building, you should be able to copy them into your Objects folder.
You can of course download the evaluation of Visual Building to verify the compatability for your self. As for the 'upgrate route' - if you mean a discount to upgrade to a more powerful version, then we can apply the 'Competitive Upgrade Discount' as we have no real way of determining proof of ownship of products from other products. |
I use an older Ashampoo version of your software and have some questions:
1. Is there an upgrade route to visual building? 2. Will my ashampoo 3d cad architecture projects load into Visual Building 3. Can I use my additional objects that I purchased for my Ashampoo software? |
