I think what is happening here is that the actual Timezone value is being recorded and not the actual location. ((ie Casablance or London). As Casablanca is the first in the list, then it is the first to always appear. As Casablanca is in the same timezone as London, it does not affect any calculation. The same problem occurs if choosing between Amsterdam and Warsaw. Amsterdam always wins because they are in the same timezone and is first in the list. Bug raised but it does not affect any calculation.
This affects all versions of Visual Building. |
In the Sun position dialog I want to change the default timezone to London. I select Dublin Edingburgh, Lisbon, London as my timezone and then Load the positon data for Country = UK and city = London,. But the Timezone changes to Casablanca? Even if I use the 'save as default' button I can never change the Timezone to be London. Is this a bug?
