Thanks for that - I didn't close and reload, just saved to disk and sent the project file. I'll add that to my list of tips and tricks - if in doubt in future, save and reload. Applies to my brain, too.
Thanks, glad I don't have any rework to do! Chris |
Chris,
I loaded the project you supplied and could not reproduce the effect you show. I assumed you tried to clear by saving and reloading the project. (Clears several visual artifacts). I have seen triangular ceiling before, which are normally caused by badly placed walls- which is not your case. I was however able to manually add a ceiling without problems. |
Hi again,
I can't quite work this one out - the Garden room seems complete, has a floor and room name, and a dotted boundary wall (- nice design touch!) However, the ceiling is triangular - I have no clue what to look for to remedy this, when the room is complete and the wall heights are the same. One possibility is that the different ceiling height in the utility room might be causing a problem? Any ideas appreciated, thanks. (Enjoying 4.02!) |
