You scales is set so that this will only print to A3 landscape. You dont say which pdf output software you are using up a common fault is to have the resolution set to high. Ensure it is 150 dpi.
Do you see anything different in your print preview: See also: PDF File not printing |
Hi.
I'm trying to print to pdf which I have had no problems before but this time when I print, When it saves it and you reopen it there is detail missing from original. Carl
