Just right click on the door (or window), and select from the context menu:
Change opening direction or Change opening hinge Applies to all versions of Visual Building |
I cant find how to change the opening direction of my doors after placing them. If you dont get it right after placement how do you change it, other than deleting it and re inserting it?
The door properties dialog does not have this data. I know its possible because I did it once, but cant find the way. [SuePuppy] |
