Compare Visual Floor Planner and VB Basic 21 Apr 2014 11:02 #1401
Ian,
Minor updates will be free, and the next minor update is now in test and will be available next month. We will include some new 2D objects with this and I think this includes some additional heating objects.
Compare Visual Floor Planner and VB Basic 21 Apr 2014 11:00 #1400
Another thought. If you are upgrading for epc use it would be useful to be able to calculate the HLP and display the total length and breadth, and total area. This can be either inside or external dimensions. Thanks
Compare Visual Floor Planner and VB Basic 21 Apr 2014 10:55 #1399
Hi Thanks for the reply. I think that visual floorplanner is what I shall require. If I purchase now will I be able to update to receive the epc objects and do you know when this will be available? Thanks
Compare Visual Floor Planner and VB Basic 20 Apr 2014 14:50 #1398
Ian,
Visual Building and Visual FloorPlanner are two very different products.
Please see this topic for for details on the comparison and objectives of both. In response to your specific questions:
Saving same formats
Both can save project as .pdf. jpg. png. Visual Buildings projects are .cyp specific to Visual Building, and Visual FloorPlanner saves its projects as an XML file.
Can you have all floors on 1 plan
Visual FloorPlanner: yes
Visual Building: yes but with Professional version.
EPC Objects
In Visual Building you can easily create any 2D symbol you require.
We are currently upgrading Visual FloorPlanner to include range of objects required for EPC. The current list of 2D objects found in Visual FloorPlanner is here .
Compare Visual Floor Planner and VB Basic 20 Apr 2014 14:00 #1397
Hi I have been looking for a feature comparison between visual floor planner and visual building basic but cannot find one. I know that visual basic has the 3d facility but are there any other differences? For example can you save to the same formats in visual basic and is it as easy to use for 2d plans? Can you have the first and second floors on one plan? Much or my work is 2d and EPC's but the 3d facility may come in useful. Finally, do you have objects for boilers, radiators, water cylinders etc. for EPC floor plans? Thanks
Time to create page: 0.094 seconds
