To place a cutout in a ceiling you do need to have a correctly formed room. A bad wall connect could give you the result you experienced. Other cause would be if you extend the cutout over a wall. If problem persists then send us the project with details of where/when you cant place the ceiling cutout.
Hi
I tried that a few time put I couldn't get it to work, it said 'At the selected position is no object, in which the opening can be paced'. I've just tried it again and it's worked, don't know why. Could I have deselected somethign or not selected the ceiling coorectly before trying to place the opening? Many thanks Karl |
I'm very new to this software, so it possible I must be missing on how to do the following.
I wish to create a opening between the Ground floor and the 1st floor, I've attached an image showing the area I wish to open up, as you can see there is a window that is almost full hight over 2 floors. If anyone can help me I would be grateful Many thanks Karl |
