brick boundary walls in environment 04 Apr 2015 11:15 #2075
There are several alternatives and as we have been asked this several times, we have added the solution to the Visual Building Training Course documentation. (Currently chapter 26).
Create a new layer and add the wall to this layer. Do not completely enclose an area with the wall as you will then create a new room, and you dont want that. (Leave a small gap.)
By adding it on its own layer this gives you the opportunity to turn it on/off in your 2D/3D views.
Then in the 3D view double click on each wall section and in the wall’s General dialog select the wall’ height from Automatic to manual, by inserting a wall height.
brick boundary walls in environment 03 Apr 2015 18:55 #2074
How would I add brick boundary walls into the environment using Visual Building Basic?
