Data Export 20 Jan 2016 11:50 #2441
If your architect needs just printed copies then export as a pdf file using PDF Creator.
If your architect has Autocad or another CAD program then you can Export as DWG/DXF, but this requires Visual Building Premium (not available in Basic version) . You can try this using the Premium trial version. Obviously AutoCad will not understand the 3D data.
Data Export 20 Jan 2016 11:46 #2440
Hi, I have two visual building 5 projects for my bungalow that I wish to pass to my architect. Is there a way to export the data?
Gary C
