Adding or Changing Catalogue Path 15 May 2014 09:17 #1477
You may want to add your own catalogue that Visual Building searches for Textures, Objects and Materials. To do this Select the Application menu (Green arrow in top left). Then select Settings - Program
This will activate the following dialog, where you can add additional paths to be searched:
The existing entries point to the current default catalogues. Best not remove these or you will lose access to them.
Time to create page: 0.116 seconds
