You will be pleased to know that our kitchen sizes are not USA sizes, but are European sizes, i.e 900 mm high and 600 mm wide. Where you require different sizes for bespoke work, you can change the size of the units,
As far as the display of the standard Kitchen units- all Visual Building version have the same features. In addition, Visual Building Basic has some 3D editing tools allowing you to create some basic furniture objects. See Creating Furniture However there are differences should you want to import 3D objects from SketchUp (via 3ds) then you would need Visual Building Professional. See: Importing a Sketchup Model Visual Building Professional / Premium has tools that will allow you to edit existing objects and even create your own. See 3D Object Converter |
I am currently considering buying a VB product. I have previously bought kitchen design software (not VB) and been disappointed because the cabinet and appliance dimensions were all American, so no use in the UK. Can you confirm please that VB kitchen cabinets and appliances are in UK standard sizes i.e. 600mm, 400mm, 300mm etc. and also is the user able to define their own dimensions because corner units and filler panels vary by different manufacturer. Finally, which version of VB is best for kitchen and bathroom design? Many thanks, Neil
