This dotted outline is the ceiling outline.
You can either 1. Do not display the ceiling in the 2D view. Remember each view has its own view options. (Right click on view and select Visibility from context menu). 2. or select the dotted line or ceiling element, then right click on it to activate Ceiling Properties- where you can change line type to invisible. See also |
The screenshot shows an extension added to the original building, with the solid line room boundary visible and a dashed line running parallel to it. When the visibility of room boundaries is switched off, the solid line disappears, but the dashed line remains. What is the dashed line and how can it be hidden (particularly when sending to print)?
The dashed lines only seem to arise with room boundaries. I have searched the Forum for the answer, but without success. Many thanks Regards Paul via email |
