The default roof construction method uses the Traditional or Cut Roof method of construction.
We do show an example of a roof design using a Truss Roof, but this truss was imported from a specialised roof truss design application (Mitek). The roof truss could be created in Visual Building, if you known the dimensions. See Truss Roof |
I am very impressed by what I see on your web site, but need to know what roof construction methods does your software support.
Can I design a Traditional Roof (also known as 'Cut Roof')? Can I design a Bolted Truss Roof? Can I design a Truss Roof using truss plates? |
