Fire Escape Catalogue Text Boxes 11 Nov 2014 11:38 #1840
Drag the drawing info text box from the catalogue into the 2D view. Then select the placed box, and right click it to activate the context menu and select 2D symbol seperate to base object. You can now double click on the text to edit it.
If you want to save this new drawing info box to the catalogue:
Drag a selection arround entire box lines and text and then from the Selection tab select Group
Select the grouped object and then right click to activate context menu and select Save selected objects as 2D symbols.. You will need to give Visual Building Admin rights tro save to the 2D symbol catalogue.
Fire Escape Catalogue Text Boxes 11 Nov 2014 11:31 #1839
The Fire Escape Catalogue contains some predefined drawing information boxes. How can I edit these to change the default text used.
Mike K via email
