Curved Wedge 04 Nov 2015 17:57 #2360
Using the 2D polygon tool create a 2D Profile of the verge and save this in the Profile catalogue (located at
C:\Program Files\Visual Building Premium 5.2.1.0 \AEC\Profiles)
Use the line tool to draw the path of the verge, in this case along the wall line.
Then use the Construction - Sweep Solid - Select Path Contour tool
The above example exaggerates the solution with limited number of wall sections.
Curved Wedge 04 Nov 2015 17:49 #2359
I have created a Construction element extrusion Solid from a on plane drawn from a Polygon based Surface element. The result is shown as the grassy area next to the fence. (surface element, underneath) I now need to turn this grassy area effectively into a curved wedge, with high side following the contour of the fence, to reflect a sloping border.
What would recommend as the best way to achieve this ?
Gerry D via email
Time to create page: 0.197 seconds
