Request wall input with direction buttons on keyboard 09 May 2019 12:49 #2817
as far as I understand we already have a similar function. When you insert a wall, a dialog with numeric distance and angle should appear in which you can make your settings, always related to the active wall side, which can be toggled with CTRL + W.
If the dialog doesn't appear, it has been set invible. In this case press W on your keyboard after the starting point of the wall has been set with a left mouse click. The visibility of the mentioned dialog can also be toggled on and off with W.
Regards
Request wall input with direction buttons on keyboard 05 May 2019 08:25 #2815
  • Dave Hickman
  • Dave Hickman's Avatar Topic Author
set wall length press the up arrow and a dialog box would appear enter measurement, same with all the other directional keyboard buttons
