Unfortunately, there is no general solution to these effects. The starting point is always a problem with the 3D terrain solid, but this can have various reasons. We need to see the project file and check what is causing the problem. Please send the project to customercare@visualbuilding.co.uk. Thomas |
I have a project with several spot heights and contours. Some Terrain objects appear ok, like a Terrace on top of the Terrain and hence is visible in 3D view. However, if I make a new Terrace or Path, it remains down at "0.0m" and so is underground and invisible in 3D (unless I turn ground off, then I can see it below). Even if I change its "height above terrain" to a positive value, the object still does not rise above ground. Can anyone assist me please? Thanks. |
