2D printing 08 Apr 2014 11:19 #1373
Ah, simple when you know how - thank you.
2D printing 08 Apr 2014 11:10 #1372
Its when the wire frame appears (this is to the paper size relative to your current scale) that you press Esc key. The Print preview window then appears and then you click on OK to print.
See also: Printing Tutorial
2D printing 08 Apr 2014 09:58 #1370
Manual section 13.8 says: "If you wish to print the complete contents of the view, without regard to scale, you can skip setting the printable area with Esc, using ‘Cancel with’ in the context menu, or with ‘Enter’. In this case, the print preview is also opened immediately."
I can't make this work - whatever I do, I get a wire frame which allows me to select only part of my 2D floorplan for printing. I want to do what the manual says - print the entire floorplan regardless of scale, i.e. on a single sheet of A4.
What am I missing please?
