3D EXPORT TO GOOGLE EARTH 25 Nov 2014 08:27 #1877
We have sent the latet version to download to your email address.
As you found, the Export function is located in the Application menu (Green Arrow top left) - Export. Also The 3D Formats menu will only be active if you have a 3D as the currently selected view.
3D EXPORT TO GOOGLE EARTH 24 Nov 2014 23:24 #1876
I think I just found the export button.
3D EXPORT TO GOOGLE EARTH 24 Nov 2014 23:19 #1875
Please could you provide advice on the following issues:
1. I have Professional which is less than 12 months old is there an update which I am able to get as I do not think I can down load..
2. MORE IMPORTANT I have watched as tutorial about exporting a 3d to google earth via sketch up. However the export button does not appear to be available could you assist, as the tutorial suggest this is possible even in the lowest level of visual build. kind regards mike
