Roof going strange for Chalet Bungalow with bays 16 Feb 2016 09:54 #2458
Hi Jackie,
Thank for the screen shots.
Would you be able to email your project file to customercare@visualbuilding.co.uk and i will have a look at this for you.
Also would you be able to tell me which version of the software you are using,so I can use the same software.
Regards,
Customer Care
Roof going strange for Chalet Bungalow with bays 15 Feb 2016 23:01 #2457
  • Jackie Pooley
  • Jackie Pooley's Avatar Topic Author
I am renovating a chalet bungalow and want to raise the roof.
The front of the existing bungalow has two sizable bays that I want to extend upwards into the roof to act as dormers.
When trying to get the effect right using the Roof construction tool, I raised the roof side height for a bay, and then did a "Multiple copy" to the other roof sides effecting the bays.
On pressing the Transfer button the roof of the bungalow went crazy.
I have tried changing the side roof heights individually but as soon as I alter one of the "inner side roofs" the roof goes crazy.
Can anyone help? Is this a bug?
(Screenshots are attached)
P.S. If there is only one bay on the front of the bungalow raising the roof sides works just fine.
