Using metal cladding on roof cause many eaves details to partially display 21 Apr 2020 08:16 #2842
you switch the gutters off on the cladding property page in your roof dialog. Maybe in combination with setting the eaves details back to "visible rafter ends"
Using metal cladding on roof cause many eaves details to partially display 20 Apr 2020 17:37 #2841
  • Gary Morin
  • Gary Morin's Avatar Topic Author
Just a quick post to highlight problems with using metal roofs.
Generally i'm getting good results, but there seems to be a few problems around using metal roof cladding, the eaves do not get created correctly as already discussed. But then lead to other problems, if I create a cross section it does display the gutter and eaves details although it does not display in the 3d view or plans. This makes difficult to create and place you own gutters and eaves as you have two versions.
Is there a way to turn of the automatic creation of the gutter etc.?
Thanks
