Re: Trial does not work. 08 Sep 2012 21:56 #374
I dont think there is a video, but its explained in
www.visualbuilding.co.uk/support/visual-building-documentation Page 273.
The video is high on our ToDo list....
Re: Trial does not work. 08 Sep 2012 20:32 #372
Visual Building Basic upwards will allow you to create elevations. If you want to display multiple elevations on a single sheet then you will need Visual Building Premium upwards.
Re: Trial does not work. 08 Sep 2012 20:27 #371
Thank you all. I have it working now. I had turned off the internet via software.
I pulled the plug on my router and it installed and updated.
Before I delve too deep into the software, could you tell me if it's capable of printing elevations and cross section plans
(with dimensions) suitable for submission for a building permit? It doesn't appear so.
George
Re: Trial does not work. 08 Sep 2012 19:42 #370
George- I should have added the need tto reboot.
Sean- The bug should have been fixed by the update. Do you still have the problem?
Re: Trial does not work. 08 Sep 2012 14:02 #369
  • Sean Johnson
  • Sean Johnson's Avatar Topic Author
The suggested work-around was successful for me. I was under the impression the fault had been fixed via the updates. Sorry I can't be of any further help.
Re: Trial does not work. 08 Sep 2012 13:36 #368
I have the same problem. The suggestions provided do not work. Please advice.
