If you want to show additional section data as additional supporting views (eg section view of a foundation or roof construction), you can import .png / .bmp images to place within your drawing, using the 2D Graphic / Insert bitmap tool.
The elevation/section view is derived only from the the section line placed in a 2D plan view, and can not be imported. You can however set the scale of each individual 2D view, including section/elevation views.
To create a solid elevation view (as opposed to a section view) place the Section view line in front of the building so that there is no section point. Applies to all versions of Visual Building. |
