Re: Dormer Ridge Height 20 Mar 2013 18:34 #655
Fantastic thank you, I'd looked at dormer height but not changed each side.
Once again thanks for the swift reply.
Re: Dormer Ridge Height 20 Mar 2013 17:40 #654
There is a height adjustment. The above image shows 2 dormers, previously the same ridge height, but then the left dormer's height reduced, using the height parameter.
To access this dialog do the following:
1. Double click on the dormer roof which.
2. The height then needs to be set for both the Left and Right side of the dormer
Dormer Ridge Height 20 Mar 2013 17:23 #653
Hi
Is there a way of adjusting the eaves and ridge height height of a dormer roof? I need to keep the roof pitch at 45 and make the dormer less tall.
Any ideas?
