Re: 2D-DWG 10 Apr 2013 21:55 #708
  • 's Avatar
You need to have an open project into which you can import. If you click on New to open a new project, you will see the Import DWG will become active.
Hot Tip: If you find that a feature does not work or is not available, ensure that you have a project open and try again. Some features need a 2D window and some need a 3D window to be open.
See: Import DWG File
2D-DWG 10 Apr 2013 21:53 #707
Hi have upgraded to pro and it says 2D-DWG are licenced but when i click import button it is greyed out ???
Jim via email
