Re: Dimension Lines style and size 31 Jul 2013 14:04 #876
Right click on the Dimension tool in the left toolbar. This will activate the Dimensions Properties dialog. Click on the Details tab and all the options in the dialog will now allow you to change all properties of the dimension line. For a 1:10 scale you will want to set the Dimension line end symbol to a size of 0.03 m.
You can then save as your default setting by clicking on the Save As Default button on right hand side of dialog.
The following foundation section drawing is on A3 at scale 1:10
Dimension Lines style and size 31 Jul 2013 13:14 #875
I have been using the default dimension lines on a plan drawing at a scales of 1:100 and 1: 50 and these look perfect for my requirements. I now need to create a section foundation detail at a lower scale of 1:10 and the size of the dimension symbols are too large. How can I adjust the symbol size to suit the scale.
Thanks for any advice Robert
[via email]
