To apply a texture to the individual wall, you need to activate the wall's properties dialog (Right click on wall and select Properties), then in the dialogs Layer construction tab, select the Material, which activates the Building Materials dialog where you can change the texture used in the 3D View.
See also: Import brick textures Weatherboard on External walls Texture change only selected part of external wall |
