To place the wall relative to a wall side and not its centre line use Ctrl + W key combination to toggle through the options.
Dear Visual Building,
When I create walls, setting first "base line" would be prefered rather than after completion. I believe that in the most case in masonry construction we do not use centrelines but left or right side. So I could not set it and I do not know how can I get this options of "Relating to..." sides. If it is not possible I would like to suggest to add this little enhancement for the next wishlist. Thanks Andras |
